I am looking for something similar to a motorized Slide Potentiometer like at this link (Adafruit Learning System), but I need it scaled up to have a roughly 300mm slide, i can only seem to find them as 100mm max.
Greetings,
I don’t imagine that something of the sort that’s 300mm (12") in length is something that a person’s likely to find as a stock item anywhere, seeing as how a unit that long would be rather unwieldy in an audio mixing console or similar devices where they find commercial use.
Assuming that this is for a one-off sort of application, a person could consider building their own using a multi-turn rotary pot, driven using a string across the back of a slide assembly, somewhat like a capstan winch but in reverse.
