Hi, Not sure this is the right forum but seemed to be the most relevant one…I’m looking for an SMD-DIP adapter, to mount my 6-pin SMD LED:https://www.kingbrightusa.com/images/catalog/SPEC/AAAF5051-05.pdf to breadboard (0.1 inch pin spacing). Could you kindly recommend an adapter?
Welcome to the DigiKey tech forum.
We do have some SMD to DIP breakout board adapters such as in link here. However these don’t specifiy the 6SMD gull wing type. You will have to look at the dimensions of each to see if any of these in stock options would fit your needs.
We don’t seem to have the 6 pin ic socket adapters in that type as seen here.
