So you just got your new Red Pitaya
Congrats! make sure to ping us and let us know about your next interesting project!
Here is a quick reference guide for the most Frequently Asked Questions:
How to get started with RP? -
https://redpitaya.readthedocs.io/en/latest/quickStart/quickStart.html
How can I start using RP measurement applications?
https://redpitaya.readthedocs.io/en/latest/quickStart/first.html
Video tutorial: How to connect to Red Pitaya board - YouTube
How to control RP remotely using LabVIEW, MATLAB, Python?
https://redpitaya.readthedocs.io/en/latest/appsFeatures/remoteControl/remoteControl.html
How to start with FPGA development?
https://redpitaya.readthedocs.io/en/latest/developerGuide/software.html
Problems connecting to RP?
https://redpitaya.readthedocs.io/en/latest/quickStart/troubleshooting/troubleshooting.html
How to upgrade OS?
https://redpitaya.readthedocs.io/en/latest/quickStart/SDcard/SDcard.html
Video tutorial: How to install/update Red Pitaya OS - YouTube
How to report a bug?
Feedback icon is present inside the web main GUI.
How to connect the external clock to RP?
https://redpitaya.readthedocs.io/en/latest/developerGuide/125-14/extADC.html
https://redpitaya.readthedocs.io/en/latest/developerGuide/122-16/extADC.html
Web interface not functioning properly or experimenting freezing.
Please check if Ad blocker has been disabled on your browser and also check your proxy settings. For local connection to Red Pitaya unit proxy settings should not be required.
Red Pitaya not booting anymore.
Possible cause can be a corrupted card, and the recommendation is a manual OS re-write: 1.5. Prepare SD card — Red Pitaya 0.97 documentation
Is there a hardware difference between the STEMlab125-14 and the ISO17025 versions.
No, the hardware is identical, the only difference is that the later would have been sent to a certification lab and the appropriate measurements were made.
Undesired disconnections.
We recommend testing on a different computer, check the state of the Ethernet cables and power supply, proxy settings, re-write OS.
Red Pitaya not booting even after OS update.
Please use the BalenaEtcher application to re-write manually the OS. Disk imager is reported broken by the latest windows update.
Red Pitaya failing to update.
Wifi dongle not detected.
Please note that not all are compatible, list is in the documentation:
https://redpitaya.readthedocs.io/en/latest/developerGuide/os/network.html?#supported-usb-wi-fi-adapters
Red Pitaya’s STEMLAB 125-14 STARTER Kits actual comparison
IZD0007 vs IZD0042 vs IZD0040 vs IZD0033 vs IZD0041 with Gen 2
Red Pitaya Unveils Its 2nd Generation Software-Defined Instrumentation Boards
confirms 3 models in the Gen 2 line-up incl. 1 with larger AMD Zynq 7020 FPGA
