If someone is concerned about the soldering of the Microphone Condenser CMC-6036-40T (DigiKey Part Number: 102-4100-ND) from Same Sky (Formerly CUI Devices), please note that this part is not a Surface Mount Device. So, wave soldering and solder reflow process should not be applied on it.
The solder pads (shown in the below image) on the bottom of the part are meant for the leads to be soldered to.
The typical soldering conditions for hand soldering this part can be found in the datasheet as follows:
