Soldering Iron Tip
I ordered ECG J-SSA-1 soldering system from DigiKey several years ago and now its tip has to change.
I need to get a tip to be able to solder smaller pitches, 8-WSON package with 0.5mm pitch.
What is a replacement soldering tip I can order that fit my soldering gun.
Thanks.
Hello Kaveh,
For the J-SSA-1 station we have a couple of options for replacement tips which you will find here:
In regard to soldering the 8-WSON package, I want to caution that the package is going to be very, very small and you may be better off using a heat gun (depending on your PCB). If you must hand solder it, though, the chisel tip might be your best bet.
