Hello, how can I get a connection cable for the SPRINTIR_W-F Gas sensor. The one I purchased recently came with none.
Thank you.
Thank you.
Specifically, the SPRINTIR_W_F-100
Hello asmaurabe and welcome to the DigiKey TechForum.
It appears that the eval kit comes with a connector to USB-A. Would you be looking for a cable similar to this one or were you wanting to be able to connect in some other way?
Hello nick,
Thanks for getting back. Actually, my order came without a connection cable. A usb-sesnor connector like the FTDI or UART cable. I have tried using the previous ones I have here with me (pictures attached)
and none worked with it. Also, what software is compatible with the sensor, I use a GSS CO2 sensor for SPRINTIR-R-100 and EXPLOR-R-20. But its not picking up with the SPRINTIR-W-F-100.
