PRO models are typically not compatible with non-pro models. Accessories may be designed specifically for 110V or 220V models. Please verify part numbers and compatibility before ordering by reviewing datasheet specifications.
- Some links may direct to a blank page for a part we do not currently carry but are linked in the event we begin to stock them. Otherwise, click here for our Special Order Product Request Form to have a part specially ordered.
Soldering Stations
** Multi-tool compatibility
Tweezer Stations
De-Soldering Stations
Hot Air Rework Stations
All-In-One Stations
Sources:
https://www.sra-shops.com/pub/media/docs/srasolder/datasheet/tds-ao-compatibility-chart.pdf
https://www.sra-solder.com/pub/media/wysiwyg/Everything_Else.jpg
https://www.sra-solder.com/pub/media/wysiwyg/Solder_Chart_.jpg
Click here for all DigiKey Soldering Products
Applicable Part Numbers
2260-AOB012-ND
2260-AOB003A-ND
2260-AOB016-ND
2260-AOT004-ND
2260-AO8800-ND
2260-AOB033-P-ND
2260-AOT002-ND
2260-AOT007-ND
2260-AOT008-P-ND
2260-AO9311-ND
2260-AOB003B-ND
2260-AOB028-P-ND
2260-AOB034-P-ND
2260-AOT005-ND
2260-AOB0028-P-ND
2260-AO9378-3D-ND
AOB012
AOB003A
AOB016
AOT004
AO8800
AOB033-P
AOT002
AOT007
AOT008-P
AO9311
AOB003B
AOB028-P
AOB034-P
AOT005
AOB0028-P
AO9378-3D
2260-AO1124-ND
2260-AO1191-ND
2260-AOLF-2B-ND
2260-AOLF-24D-ND
2260-AOLF-02J-ND
2260-AOLF-LI-ND
2260-AOLF-2BC-ND
2260-AOLF-1403-ND
2260-AOTCHISEL.SET-ND
2260-AOTBEVEL.SET-ND
2260-AOT-32LD-ND
2260-AOT-18H-ND
2260-AO1132-ND
2260-AO1616-ND
2260-AO1125-ND
2260-AO1142-ND
2260-AOLF-52D-ND
2260-AOLF-1402-ND
2260-AO1129-ND
2260-AOLF-1401-ND
2260-AO1181-ND
2260-AOT-24D-ND
2260-AOT-S3-ND
2260-AOT-08C-ND
2260-AOT-1C-ND
2260-AOT-I-ND
2260-AOT-08D-ND
2260-AOT-05C-ND
2260-AOT-SI-ND
2260-AOT-S8-ND
2260-AOT-12D-ND
2260-AOT-LB-ND
2260-AO1130-ND
2260-AON-1315-ND
2260-AO1126-ND
2260-AOSGL.SET.2-ND
2260-AOBGA.SET2-ND
2260-AOT-S4-ND
2260-AOT-32D-ND
2260-AOT-S9-ND
2260-AOT-2LD-ND
2260-AOT-2CF-ND
2260-AOT-2C-ND
2260-AOT-4C-ND
2260-AOT-S7-ND
2260-AOT-SB-ND
2260-AOT-15CF-ND
2260-AOT-1CF-ND
2260-AOT-16D-ND
2260-AOT-B-ND
2260-AOT-3C-ND
2260-AOT-02RB-ND
2260-AOT-R-ND
2260-AOT-K-ND
2260-AOT-RT-ND
2260-AO1198-ND
2260-AO1196-ND
2260-AO1197-ND
2260-AO1194-ND
2260-AO1195-ND
2260-AON-1320-ND
2260-AON-1305-ND
2260-AON-1302-ND
2260-AO1192-ND
2260-AO1260-ND
2260-AO1261-ND
2260-AO1140-ND
2260-AO1313-ND
2260-AO1186-ND
2260-AO1188-ND
2260-AO1258-ND
2260-AO1135-ND
2260-AO1010-ND
2260-AO1133-ND
2260-AO1136-ND
2260-AO1134-ND
2260-AO1131-ND
2260-AO1919-ND
2260-AOLF-1C-ND
2260-AOLF-B-ND
2260-AOLF-12LD-ND
2260-AOLF-12D-ND
2260-AOLF-3BC-ND
2260-AO1214-ND
2260-AOLF-I-ND
2260-AOLF-1BC-ND
2260-AO1180-ND
2260-AOLF-08LD-ND
2260-AO1262-ND
2260-AOLF-LB-ND
2260-AOLF-16D-ND
2260-AO1325-ND
2260-AO1141-ND
2260-AO1257-ND
2260-AOLF-K-ND
2260-AO1189-ND
2260-AO1259-ND
2260-AO1128-ND
2260-AO1127-ND
2260-AO1182-ND
2260-AO1265-ND
2260-AO1137-ND
2260-AOSGL.SET.1-ND
2260-AOSGL.SET.3-ND
2260-AOSOP.SET-ND
2260-AOBGA.SET-ND
2260-AOPLCC.SET-ND
2260-AOT-3CF-ND
2260-AOT-S6-ND
2260-AOT-4CF-ND
2260-AOT-12LD-ND
2260-AO1139-ND
2260-AO1185-ND
2260-AO1184-ND
2260-AO1187-ND
2260-AOLF-4C-ND
2260-AOLF-4CF-ND
2260-AOLF-2BCM-ND
2260-AOTCONICAL.SET-ND
2260-AOT-H-ND
2260-AO1183-ND
2260-AO1203-ND
2260-AO1264-ND
2260-AO1215-ND
2260-AO1138-ND
2260-AO1263-ND
2260-AOQFP.SET-ND
2260-AON-1310-ND
AO1124
AO1191
AOLF-2B
AOLF-24D
AOLF-02J
AOLF-LI
AOLF-2BC
AOLF-1403
AOTCHISEL.SET
AOTBEVEL.SET
AOT-32LD
AOT-18H
AO1132
AO1616
AO1125
AO1142
AOLF-52D
AOLF-1402
AO1129
AOLF-1401
AO1181
AOT-24D
AOT-S3
AOT-08C
AOT-1C
AOT-I
AOT-08D
AOT-05C
AOT-SI
AOT-S8
AOT-12D
AOT-LB
AO1130
AON-1315
AO1126
AOSGL.SET.2
AOBGA.SET2
AOT-S4
AOT-32D
AOT-S9
AOT-2LD
AOT-2CF
AOT-2C
AOT-4C
AOT-S7
AOT-SB
AOT-15CF
AOT-1CF
AOT-16D
AOT-B
AOT-3C
AOT-02RB
AOT-R
AOT-K
AOT-RT
AO1198
AO1196
AO1197
AO1194
AO1195
AON-1320
AON-1305
AON-1302
AO1192
AO1260
AO1261
AO1140
AO1313
AO1186
AO1188
AO1258
AO1135
AO1010
AO1133
AO1136
AO1134
AO1131
AO1919
AOLF-1C
AOLF-B
AOLF-12LD
AOLF-12D
AOLF-3BC
AO1214
AOLF-I
AOLF-1BC
AO1180
AOLF-08LD
AO1262
AOLF-LB
AOLF-16D
AO1325
AO1141
AO1257
AOLF-K
AO1189
AO1259
AO1128
AO1127
AO1182
AO1265
AO1137
AOSGL.SET.1
AOSGL.SET.3
AOSOP.SET
AOBGA.SET
AOPLCC.SET
AOT-3CF
AOT-S6
AOT-4CF
AOT-12LD
AO1139
AO1185
AO1184
AO1187
AOLF-4C
AOLF-4CF
AOLF-2BCM
AOTCONICAL.SET
AOT-H
AO1183
AO1203
AO1264
AO1215
AO1138
AO1263
AOQFP.SET
AON-1310
2260-AO888A-ND
2260-AO888A220V-ND
2260-AO474A+±ND
2260-AO968A±ND
2260-AO852A+±ND
2260-AO852A++220V-ND
2260-AO701A+±ND
2260-AO9378MICROCOMBO-ND
2260-AO853A+±ND
2260-AO968A+220VKIT1-ND
2260-AO968A+220V-ND
2260-AO968A+SRAKIT1-ND
2260-AO866-ND
2260-AO968A+22OTWZ-ND
2260-AO2703A±ND
2260-AO2703A+220V-ND
2260-AO883-ND
2260-AO469-ND
2260-AO469KIT-ND
2260-AO9378-ND
2260-AOSP1800-ND
2260-AO9378-220-ND
2260-AO469-EDU-ND
2260-AO952-ND
2260-AO9378+LFIRON-ND
2260-AO474A++220V-ND
2260-AO9378+MACRO-ND
2260-AO9378-TWZKIT-ND
2260-AO701A++220V-ND
2260-AO9378-220-LED-ND
2260-AO9378-220-LF-ND
2260-AO9378-LED-ND
2260-AO9378-220-3D-ND
2260-AO899A±ND
2260-AO866220V-ND
2260-AO9378-220-MACRO-ND
2260-AO9378-220-MICRO-ND
2260-AO9378-220-TWZKT-ND
2260-AO2702A±ND
2260-AO2702A+220V-ND
2260-AO738H-ND
2260-AO863-ND
2260-AO9378-220-LFIRON-ND
2260-AO9378-220-TWZKIT-ND
2260-SRA205-30CC-ND
2260-SRA205-5CC-ND
2260-AO853A-ND
2260-AOSP2000±ND
2260-AOSP4000-ND
2260-AO738H220V-ND
AO888A
AO888A220V
AO474A++
AO968A+
AO852A++
AO852A++220V
AO701A++
AO9378MICROCOMBO
AO853A++
AO968A+220VKIT1
AO968A+220V
AO968A+SRAKIT1
AO866
AO968A+22OTWZ
AO2703A+
AO2703A+220V
AO883
AO469
AO469KIT
AO9378
AOSP1800
AO9378-220
AO469-EDU
AO952
AO9378+LFIRON
AO474A++220V
AO9378+MACRO
AO9378-TWZKIT
AO701A++220V
AO9378-220-LED
AO9378-220-LF
AO9378-LED
AO9378-220-3D
AO899A+
AO866220V
AO9378-220-MACRO
AO9378-220-MICRO
AO9378-220-TWZKT
AO2702A+
AO2702A+220V
AO738H
AO863
AO9378-220-LFIRON
AO9378-220-TWZKIT
SRA205-30CC
SRA205-5CC
AO853A
AOSP2000+
AOSP4000
AO738H220V
2260-STOPBLUE10-ND
2260-WBBRUS-6-ND
2260-AO939+BL-ND
2260-SMDKIT-ND
2260-SMDKIT-LF-ND
2260-AO20094220-ND
2260-FASTCHIP4.5-ND
2260-FASTCHIP4.5-LF-ND
2260-SMDKIT4.5-LF-ND
2260-FASTCHIP8-ND
2260-BLACKENDFIT-ND
2260-AO8486-FILTER-ND
2260-AO8486-CARB-ND
2260-FASTCHIP8-LF-ND
2260-AO388-ARMS-ND
2260-AO20094-ND
2260-SMDKIT4.5-ND
2260-AO932-ND
2260-AOC009-ND
2260-AOC011-ND
2260-AOPCX-01-ND
2260-AOC005A-ND
2260-AO398-ND
2260-SRADROSSREM-ND
2260-AO388-MAG2-ND
2260-AOC006A±ND
2260-AO8486-HEPA-ND
2260-AOFEK-CF-ND
2260-AOFEK-MF-ND
2260-FASTCHIP16-ND
2260-FASTCHIP16-LF-ND
2260-FASTCHIP32-ND
2260-FASTCHIP32-LF-ND
2260-AO328-ND
STOPBLUE10
WBBRUS-6
AO939+BL
SMDKIT
SMDKIT-LF
AO20094220
FASTCHIP4.5
FASTCHIP4.5-LF
SMDKIT4.5-LF
FASTCHIP8
BLACKENDFIT
AO8486-FILTER
AO8486-CARB
FASTCHIP8-LF
AO388-ARMS
AO20094
SMDKIT4.5
AO932
AOC009
AOC011
AOPCX-01
AOC005A
AO398
SRADROSSREM
AO388-MAG2
AOC006A+
AO8486-HEPA
AOFEK-CF
AOFEK-MF
FASTCHIP16
FASTCHIP16-LF
FASTCHIP32
FASTCHIP32-LF
AO328
hi Ryan,if my requested for 220V for SRA soldering products
883 LARGE IR PREHEATING STATION can suitable use for 110v?
Hello purchasing4p,
The part number 2260-AO883-ND, which is the 883 Large IR Preheating Station, is designed for 110VAC.
