How to validate a PortServer TS / ConnectPort TS migration with the Digi Connect EZ 4 TS Concept Kit (EZ04-TS00-CKIT)
This walkthrough brings up the Connect EZ 4 TS from the concept kit, configures RealPort, and confirms serial traffic end to end, so you can test a legacy PortServer TS or ConnectPort TS replacement on your bench before ordering production units.
What you need
- EZ04-TS00-CKIT: Connect EZ 4 TS (4 ports, software-selectable RS-232/422/485), power supply, Ethernet cable, serial adapter cables (DB-9, DB-25, RJ-45, RS-422/485) and a diagnostic loopback plug
- A Windows PC on the same network as the device
- Digi Navigator (free download from Digi)
- Optional: the serial device you plan to connect
Steps
- Connect power, and plug the Ethernet cable into your network.
- Launch Digi Navigator. It discovers Connect EZ devices on the network and lists their IP addresses.
- Select the device and click Configure device for RealPort. Enter the device username and password and submit. This sets the serial ports to RealPort mode and enables the RealPort service.
- Click Configure this PC for RealPort. Navigator creates the COM ports on the PC, and you can choose the starting COM number. Reusing the COM numbers your application already points to means no application changes.
- Plug the loopback plug into serial port 1. In Tera Term (or any terminal program), connect to the COM port mapped to port 1, then type some text and press Enter.
- In the device web UI, refresh the page and compare the TX/RX Bytes for that port. Matching counts confirm the data path.
- Swap the loopback plug for your serial device (use the matching adapter cable from the kit), point your application at the same COM port, and run it.
Notes for TS migrations
- The Connect EZ 4 TS keeps the legacy mechanical footprint and RJ-45 serial pinout, and RealPort workflows carry over.
- Each port is software-selectable RS-232/422/485.
- TCP, Telnet and SSH access to the serial ports is disabled by default and must be enabled in the device configuration if you need it.
- The device can be managed locally through the CLI or web UI, with Digi On-Prem Manager for larger deployments. Remotely, use Digi Remote Manager, Digi’s cloud platform.
Part number: EZ04-TS00-CKIT
Docs: Digi Connect EZ 4/4i User Guide, and Digi’s “How to Configure RealPort for Serial Communications” guide.
If you are mapping a specific legacy device, post its model and serial settings below and I’ll help.
