Understanding the Difference Between ConnectPort TS and Digi Connect EZ Product Families
When selecting the right terminal server for your environment, it’s important to consider the design differences between the Digi ConnectPort TS and Digi Connect EZ product families. Here’s a quick comparison to help you decide:
ConnectPort TS Family (TS 8/16)
  • Fanless Design: These devices are built without fans, making them ideal for environments where dust, debris, or noise could be a concern. The fanless design prevents dust from being circulated, ensuring a cleaner and quieter workspace.
  • Recommended Use: Perfect for cleanroom setups, industrial environments sensitive to airborne particles, or areas requiring low noise levels.
  • View product details
  • Explore more on Digi.com
Digi Connect EZ Family (8/16/32)
  • Active Cooling with Fans: These devices include fans for effective cooling, supporting higher performance and more intensive applications.
  • Recommended Use: Ideal for office spaces, server rooms, or other controlled environments where fan operation and airflow are not a concern.
Key Consideration:
  • Choose ConnectPort TS if you want a fanless, dust-free, and quieter solution, especially for sensitive environments.
  • Choose Digi Connect EZ if you need higher performance and cooling in an environment where fans are acceptable.
By understanding these differences, you can select the terminal server that best fits your operational needs.
