I am trying to build out an Audio Moth recorder and the board uses this now obsolete part. Can you recommend one that might be a drop in replacement?
SJ2-35464A-SMT-TR 3.5 mm, Stereo, Right Angle, Surface Mount (SMT), Audio Jack Connector
KW
KW
Welcome to the Technical Forum. The closest option I can find is: SJ2-35355A-SMT-TR. You can review this: https://www.digikey.com/short/2zvdbdfq .
This was the only option I found for surface mount an 6 conductor.
Thank You For your help. I will place an order here soon.
KW
