Not so much a product suggestion as a small change. I send out products to my customers in static sensitive bags, recyclable wrapping and so on - and re-use the packaging from DigiKey and other suppliers where possible.
However, the component labels on the blue bags that you deliver to me are attached with the most difficult to remove glue I’ve come across. It’s just impossible to cleanly remove the label, so I can’t easily re-use or even recycle the bags.
Could you change the labels and/or the glue so that they can be consistently peeled off? It’s a waste to not be able to re-use perfectly good bags.
