Tact Switch for Honeywell Captuvo SL42
Good morning, I was wondering if you had any Tact switches for Honeywell Captuvo SL42.
I’ve attached pictures of the switch.
Hi Randall,
Welcome to the Digi-Key tech forum.
There seems to be no indication on switch functionality on these and other specs, even though I was able to find the SL42 device these are on. However, they don’t really list much info specific to the parts within it, so I’m checking a little deeper into this for you and will get back to you when I have some feedback.
Regards,
Great thank you!! I couldn’t find much information myself. I appreciate you looking into this for me.
Thanks
Hello randall.vogt,
These look very similar to the Edge Board Tactile switches here . I suggest you look over the EVQ series from Panasonic, spec sheet EVQ-P4_EVQ-P8.pdf (digikey.com) and check the dimensions to see if any of these will work.
Awesome!! Thank you Jeff
Good luck with the project randall.vogt, and let us know how with works out for you.
Hi again Randall,
I agree with Jeff and wasn’t able to find much more than what he already gave you. Best of luck.
