이는 TDK 전원 공급 장치에 대해 자주 묻는 질문입니다. Digi-Key 웹 사이트와 규격서에는 입력 전압이 85-265VAC로 표시되고 레이블에는 100-240V로 표시됩니다.
그 이유는 레이블은 UL 인증 전압 범위를 표시하기 때문입니다.
아래는 동일한 질문에 대한 TDK FAQ 사이트의 정보입니다.
Most power supplies have a rating label that looks something like this:
INPUT: AC 100V-240V~ 50 / 60 HzHowever, a close look at the power supply’s datasheet will usually show the absolute AC input voltage range, from minimum to maximum. This is usually 90-264Vac, or 85-264Vac if the power supply has been designed for use in Japan.
Parts of Japan use the lowest AC mains voltage, which is 100Vac nominal; however, short duration AC line droops or brown-out conditions often mandate a rating down to 85Vac. The UK is among the countries that use the highest AC mains, with a nominal rating of 230Vac +10% -6%.
The safety certification bodies (UL, CSA, TUV, etc.) mandate that a rating of 100-240Vac be listed on the power supply’s label. However, they factor in a +/-10% tolerance for the power generation and transmission utilities. -10% of 100VAC is 90Vac, and +10% of 240VAC is 264Vac. All safety testing is performed at the high and low limits as listed on the power supply’s datasheet.
So, if the power supply label states 100-240Vac, it can usually operate over a wider AC operating input range. However, always check with the manufacturer’s datasheet to confirm this. Continuous operation of the power supply over the datasheet’s specified AC input range will not normally cause any problems. In some cases, however, the maximum output power (total watts) of the power supply may need to be derated if the supply is operating off an input voltage that is on the low-end of the specified range. Always check the power supply’s datasheet for the specified minimum AC input voltage with various output load levels. Deratings may also apply depending upon the power supply’s operating ambient temperatures.
Should a label state 100/240Vac (note the slash) it “may” indicate that there is a voltage select switch or jumper that is required to be set for the correct operating input voltage range. Newer products tend to not have an AC select switch or jumper.
Worldwide, the AC mains power has a nominal frequency of either 50 or 60 Hz (cycles per second). However, these frequencies are subject to variations by the power generators in different countries (especially third world) and so the typical AC frequency range for power supplies is 47-63Hz.
적용 가능한 부품 번호
285-2362-ND 285-2251-ND 285-2252-ND 285-2285-ND 285-2289-ND 285-2288-ND 285-2384-ND 285-2293-ND 285-2292-ND 285-2322-ND 285-2294-ND 285-2321-ND 285-2506-ND 285-2185-ND 285-2298-ND 285-2296-ND 285-2297-ND 285-1403-ND 285-2439-ND 285-1742-ND 285-1791-ND 285-1792-ND 285-1741-ND 285-1790-ND 285-1788-ND 285-1743-ND 285-1322-ND 285-1938-ND 285-1795-ND 285-1798-ND 285-1797-ND 285-1793-ND 285-1794-ND 285-1800-ND 285-2166-ND 285-2511-ND 285-1475-ND 285-2109-ND 285-2011-ND 285-2504-ND 285-1687-ND 285-1406-ND 285-1937-ND 285-2509-ND 285-1285-ND 285-2290-ND 285-2382-ND 285-1688-ND 285-2041-ND 285-2874-ND 285-1476-ND 285-2256-ND 285-2383-ND 285-2291-ND 285-1405-ND 285-2324-ND 285-1789-ND 285-1318-ND 285-1363-ND 285-2039-ND 285-2161-ND 285-1455-ND 285-2217-ND 285-2211-ND 285-2208-ND 285-2359-ND 285-2360-ND 285-2696-ND 285-2700-ND 285-2253-ND 285-2284-ND 285-2107-ND 285-2004-ND 285-2013-ND 285-2182-ND 285-2758-ND 285-1690-ND 285-2341-ND 285-1404-ND 285-1327-ND 285-1368-ND 285-1359-ND 285-1362-ND 285-2037-ND 285-2038-ND 285-2223-ND 285-1456-ND 285-2510-ND 285-1287-ND 285-2332-ND 285-2214-ND 285-2210-ND 285-2207-ND 285-2216-ND 285-2206-ND 285-2212-ND 285-2354-ND 285-2255-ND 285-2254-ND 285-2352-ND 285-2353-ND 285-2286-ND 285-2105-ND 285-2108-ND 285-2106-ND 285-2367-ND 285-2351-ND 285-2366-ND 285-2111-ND 285-2115-ND 285-2369-ND 285-2005-ND 285-2385-ND 285-2010-ND 285-2012-ND 285-2009-ND 285-2363-ND 285-2364-ND 285-2505-ND 285-2507-ND 285-2180-ND 285-2239-ND 285-2347-ND 285-2348-ND 285-1692-ND 285-1691-ND 285-1693-ND 285-1689-ND 285-2553-ND 285-2547-ND 285-2541-ND 285-1021-ND 285-2184-ND 285-2183-ND 285-2220-ND 285-2218-ND 285-2219-ND 285-2300-ND 285-1024-ND 285-2440-ND 285-2437-ND 285-2438-ND 285-2508-ND 285-2545-ND 285-2551-ND 285-1320-ND 285-1329-ND 285-1939-ND 285-1319-ND 285-1328-ND 285-1321-ND 285-1799-ND 285-1361-ND 285-1365-ND 285-1364-ND 285-2040-ND 285-2222-ND 285-2221-ND 285-2162-ND 285-2163-ND 285-2326-ND 285-1284-ND 285-2014-ND 285-2792-ND 285-2795-ND 285-2797-ND 285-2884-ND 285-2802-ND 285-2799-ND 285-2801-ND 285-2699-ND 285-2701-ND 285-2697-ND 285-2885-ND 285-2873-ND 285-2113-ND 285-2811-ND 285-2813-ND 285-2812-ND 285-2814-ND 285-2815-ND 285-2843-ND 285-2881-ND 285-2673-ND 285-2875-ND 285-2817-ND 285-2676-ND 285-2674-ND 285-2675-ND 285-2678-ND 285-2677-ND 285-2882-ND 285-2842-ND 285-2350-ND 285-1016-ND 285-1017-ND 285-1018-ND 285-2883-ND 285-1019-ND 285-1020-ND 285-1023-ND 285-1022-ND 285-2877-ND 285-2876-ND 285-2761-ND 285-2768-ND 285-2769-ND 285-2760-ND 285-2759-ND 285-2731-ND 285-2865-ND 285-2864-ND 285-2866-ND 285-2762-ND 285-2867-ND 285-2764-ND 285-2763-ND 285-2770-ND 285-2765-ND 285-2730-ND 285-1370-ND 285-2868-ND 285-2728-ND 285-2365-ND 285-2238-ND 1043-SWS6003/CO2-CHP 285-1326-ND 285-1330-ND 285-1367-ND 285-1371-ND 285-1286-ND 285-2295-ND 285-2323-ND 285-1323-ND 285-2042-ND 285-2209-ND 285-2213-ND 285-2215-ND 285-2361-ND 285-2283-ND 285-2287-ND 285-2368-ND 285-2007-ND 285-2240-ND 285-1694-ND 285-1325-ND 285-1796-ND 285-2793-ND 285-2794-ND 285-2796-ND 285-2798-ND 285-2800-ND 285-2804-ND 285-2698-ND 285-2856-ND 285-2899-ND 285-2900-ND 285-2791-ND 285-1360-ND ZWS15B3-ND ZWS30B3-ND 1043-SCS403-CHP 1043-SCT47-CHP 1043-SCS4015-CHP 1043-SCS4028-CHP MTW15-51212/V-ND MTW15-51515/V-ND RWS50B12/CO2-ND RWS50B24/CO2-ND RWS50B48/CO2-ND RWS50B5/CO2-ND MTW30-51212/V-ND MTW30-51515/V-ND HWS30A24/ME-ND HWS30A48/ME-ND HWS30A12-ND HWS30A15-ND HWS30A24-ND HWS30A3-ND HWS30A48-ND HWS30A5-ND 1043-SCT68-CHP RWS100B15-ND 285-2110-ND HWS30A12/HD-ND HWS30A15/HD-ND HWS30A24/HD-ND HWS30A3/HD-ND HWS30A48/HD-ND HWS30A3/ME-ND ZWS50BAF-12/L-ND ZWS50BAF-15/L-ND ZWS50BAF-24/L-ND ZWS50BAF-3/L-ND ZWS50BAF-48/L-ND ZWS50BAF-5/L-ND ZWS50BAF-12/A-ND ZWS50BAF-15/A-ND ZWS50BAF-3/A-ND ZWS50BAF-48/A-ND ZWS50BAF-5/A-ND ZWS50BAF-12/CO2-ND ZWS50BAF-15/CO2-ND ZWS50BAF-24/CO2-ND ZWS50BAF-3/CO2-ND ZWS50BAF-48/CO2-ND ZWS50BAF-5/CO2-ND RWS100B12/CO2-ND RWS100B48/CO2-ND RWS100B5/CO2-ND 285-2112-ND 285-2114-ND 285-2116-ND ZWS75BAF-12/L-ND ZWS75BAF-15/L-ND ZWS75BAF-24/L-ND ZWS75BAF-3/L-ND ZWS75BAF-48/L-ND ZWS75BAF-5/L-ND 285-1479-ND HWS50A48-ND HWS50A15/ME-ND HWS50A48/ME-ND HWS50A5/ME-ND ZWS75BAF-12/A-ND ZWS75BAF-15/A-ND ZWS75BAF-24/A-ND ZWS75BAF-3/A-ND ZWS75BAF-48/A-ND ZWS75BAF-5/A-ND ZWS75BAF-12/CO2-ND ZWS75BAF-15/CO2-ND ZWS75BAF-24/CO2-ND ZWS75BAF-3/CO2-ND ZWS75BAF-48/CO2-ND ZWS75BAF-5/CO2-ND RWS150B12/CO2-ND RWS150B24/CO2-ND RWS150B48/CO2-ND RWS150B5/CO2-ND MTW60-51212/V-ND MTW60-51515/V-ND 285-2003-ND 285-2006-ND 285-2008-ND CUS200LD7R5-ND CUT75522/T-ND CUT755FF/T-ND ZWS100BAF-3/L-ND ZWS100BAF-5/L-ND ZWS100BAF-12/L-ND ZWS100BAF-15/L-ND ZWS100BAF-24/L-ND ZWS100BAF-48/L-ND CUT75522/TB-ND CUT755FF/B-ND CUT755FF/TB-ND CUT75522/B-ND ZWS100BAF-3/R-ND ZWS100BAF-5/R-ND ZWS100BAF-12/R-ND ZWS100BAF-15/R-ND ZWS100BAF-24/R-ND ZWS100BAF-48/R-ND ZWS100BAF-3/A-ND ZWS100BAF-5/A-ND ZWS100BAF-12/A-ND ZWS100BAF-15/A-ND ZWS100BAF-24/A-ND ZWS100BAF-48/A-ND ZWS100BAF-3/CO2-ND ZWS100BAF-5/CO2-ND ZWS100BAF-12/CO2-ND ZWS100BAF-15/CO2-ND ZWS100BAF-24/CO2-ND ZWS100BAF-48/CO2-ND CUT75522/A-ND HWS50A12/RA-ND ZWD100PAF0524-ND ZWS150BAF-3/L-ND ZWS150BAF-5/L-ND ZWS150BAF-12/L-ND ZWS150BAF-15/L-ND ZWS150BAF-24/L-ND ZWS150BAF-48/L-ND ZWS150BAF-3/R-ND ZWS150BAF-5/R-ND ZWS150BAF-12/R-ND ZWS150BAF-15/R-ND ZWS150BAF-24/R-ND ZWS150BAF-48/R-ND ZWD100PAF0524/JL-ND ZWD100PAF0524/L-ND ZWD100PAF0524/A-ND ZWD100PAF0524/JA-ND ZWS150BAF-3/A-ND ZWS150BAF-5/A-ND ZWS150BAF-12/A-ND ZWS150BAF-15/A-ND ZWS150BAF-24/A-ND ZWS150BAF-48/A-ND ZWD100PAF0524/T-ND ZWS150BAF-3/CO2-ND ZWS150BAF-5/CO2-ND ZWS150BAF-12/CO2-ND ZWS150BAF-15/CO2-ND ZWS150BAF-24/CO2-ND ZWS150BAF-48/CO2-ND HWS100A15/ME-ND HWS100A48/ME-ND ZWD100PAF0524/TL-ND ZWD100PAF0524/TA-ND RWS300B12/R-ND RWS300B15/R-ND RWS300B24/R-ND RWS300B48/R-ND RWS300B5/R-ND ZWD150PAF0524-ND ZWD150PAF0524/J-ND ZWD150PAF0524/JL-ND ZWD150PAF0524/L-ND ZWD150PAF0524/A-ND ZWD150PAF0524/JA-ND ZWD150PAF0524/T-ND RWS300B12/CO2-ND RWS300B15/CO2-ND RWS300B36/CO2-ND RWS300B48/CO2-ND RWS300B5/CO2-ND 285-2181-ND ZWD150PAF0524/TL-ND 285-2237-ND HWS150A12/ME-ND HWS150A15/ME-ND HWS150A15-ND HWS150A24-ND HWS150A3-ND HWS150A48-ND HWS150A5-ND CUS250LD5/A-ND ZWD225PAF0524-ND ZWD225PAF0524/JL-ND ZWD225PAF0524/L-ND ZWQ805224/L-ND ZWQ805222/L-ND ZWQ805223/L-ND ZWQ805225/L-ND ZWD225PAF0524/A-ND ZWD225PAF0524/JA-ND ZWD225PAF0524/T-ND ZWD225PAF0524/TL-ND ZWQ805222/A-ND ZWQ805223/A-ND ZWQ805225/A-ND ZWD225PAF0524/TA-ND ZWQ1305222/L-ND ZWQ1305223/L-ND ZWQ1305224/L-ND ZWQ1305225/L-ND 285-2543-ND 285-2549-ND 285-2555-ND ZWQ1305222/A-ND ZWQ1305223/A-ND ZWQ1305225/A-ND 285-2542-ND 285-2548-ND 285-2554-ND ZWS240BP24/T-ND ZWS240BP36/T-ND ZWS240BP48/T-ND 285-2544-ND 285-2550-ND 285-2556-ND ZWS300BAF24/T-ND ZWS300BAF36/T-ND ZWS300BAF48/T-ND 285-2299-ND ZWS300BAF12/T-ND ZWS300BAF15/T-ND ZWS240BP24/L-ND ZWS240BP36/L-ND ZWS240BP36/TL-ND ZWS240BP48/L-ND ZWS240BP48/TL-ND ZWS240BP24/R-ND ZWS240BP24/TL-ND ZWS300BAF24/TL-ND ZWS300BAF24/R-ND ZWS300BAF24/L-ND ZWS300BAF36/L-ND ZWS300BAF48/TL-ND ZWS300BAF36/TL-ND ZWS300BAF36/R-ND ZWS300BAF48/R-ND ZWS300BAF48/L-ND ZWS300BAF12/L-ND ZWS300BAF12/R-ND ZWS300BAF12/TL-ND ZWS300BAF15/L-ND
RWS50B5 HWS30A-12/A HWS30A-15/A RWS100B24 RWS150B24 RWS150B12 CUT755FF RWS300B24 RWS300B12 RWS300B36 RWS300B48 RWS300B15 CUS200M24 ZWS240BP24 RWS600B48 RWS600B12 RWS600B24 JWT100-522/A CUS350M24/F SWS600L-24 SWS600L-48 SWS600L-60 SWS600L-12 SWS600L-36 SWS600L-15 SWS600L-5 HWS300-24 RFE1000-32-Y SWS1000L-24 SWS1000L-48 SWS1000L-36 SWS1000L-12 SWS1000L-15 SWS1000L-60 HFE250048 RFE250048 MTW15-51212 ZWS50BAF24 ZWS150BAF-12 CUS200M12 ZWQ1305222 JWT75-5FF/A RFE1000-24-Y RFE250012 HWS150015/HD RWS150B48 CUT75522 ZWQ1305223 HFE1600-48 RWS300B24/CO2 MTW15-51515 HWS30A-5/A CUT75522/TA RWS300B5 JWT75-522/A RWS600B36 SWS600L-3 HWS300-12 HWS600-24 HFE1600-24 HFE250024 LZSA-1000-3 ZWS10B5 ZWS30B12 ZWS30B24 RWS50B12 RWS50B24 CUT35522 CUT355FF/A HWS30A-24/A RWS100B12 ZWS50BAF5 ZWS100BAF-5 ZWS150BAF-24 ZWS150BP24 ZWD225PAF0524/J ZWQ1305225 ZWQ1305224/A JWT100-5FF/A HWS300-48 HWS600-48 HWS600-12 HWS600-15/HD HFE1600-12 HFE1600-12/S RFE160048 LZSA-500-3 RFE250024 HWS150024/HD LZSA-1500-3-001 ZWS10B12 ZWS10B15 ZWS15B15 ZWS15B5 ZWS15B12 ZWS30B5 HWS30A5/ME HWS30A-48/A HWS30A-3/A HWS30A15/ME HWS30A24/ME RWS100B48 ZWS50BAF12 ZWS50BAF15 ZWS50BAF3 HWS30A5/HD HWS30A12/HD HWS30A24/HD ZWS75BAF12 ZWS75BAF24 HWS50A24/ME ZWS100BAF-12 CUT755FF/TA ZWS150BAF-5 ZWS150BAF-15 ZWS150BAF-3 HWS100A12/ME HWS100A24/ME CUS200M18 CUS200M48 ZWS150BP48 CUS250LD12 HWS150A24/ME HWS150A48/ME ZWQ805223 ZWQ805222 ZWQ805224 ZWQ1305224 EVS57-5R3 EVS36-8R4 EVS18-16R7 LWT-30H-5FF ZWS240BP36 ZWS240BP48 ZWS300BAF24 ZWS300BAF36 ZWS300BAF48 ZWS300BAF15 LWT-50H-5FF CUS350M48/F CUS350M12/F CUS350M18/F CUS350M36/F EVS36-16R7 EVS57-10R6 HWS300-15 HWS300-5 RFE1000-48-Y HWS300-12/HD HWS300-48/HD HWS300-15/HD SWS1000L-5 HWS600-15 HWS600-24/ME HWS600-24/HD HFE1600-24/S RFE160024 RFE160012 HFE250012 HFE250024/S HWS1000-24 HWS150015 ZWS150BAF-48 CUS30M12 CUS30M24 CUS30M48 ZWS10B3 CUS60M24 CUS60M12 CUS60M18 CUT355FF CUT355FF/B CUT35522/A ZWS50BAF-24/A RWS100B24/CO2 ZWS75BAF5 CUS200LD12 CUS200LD24 CUS200LD15 CUS200LD48 CUS200LD5 CUT755FF/A ZWD100PAF0524/J CUS200M36 RWS300B36/R ZWS240RC24 CUS200M24/A CUS200M12/A CUS200M18/A CUS200M48/A CUS200M36/A ZWD150PAF0524/TA CUS250LD4 HWS150A5/ME LWT-15H-522 LWT-15H-525 LWT-15H-5FF ZWQ805224/A LWT-30H-522 LWT-30H-525 LWT-50H-525 LWT-50H-522 RWS600B48/RFO RWS600B12/RFO RWS1000B48/ME RWS1000B12/ME RWS1000B24/ME RWS1000B36/ME RWS1000B15/ME NNS155 NNS1515 NND151515 NNS1524 RWS1500B12/ME NNS3015 RWS1500B36/ME RWS1500B15/ME RWS1500B24/ME RWS1500B48/ME NND301515 HWS600-5 NNS5012 LZSA-1000-2 HWS100A5/ME CUS250LD24 SWS6003/CO2 HWS300-3/HD HWS300-5/HD HWS600-3/HD HWS600-5HD HWS150024 RWS600B5 RWS600B15 HWS300-24/HD HFE1600-48/S ZWS10B24 ZWS15B24 ZWS30B15 RWS50B48 RWS100B5 RWS150B5 HWS50A12/ME ZWS100BAF-24 CUS250LD-5 ZWQ805225 HWS300-3 SWS1000L-3 CUS30M15 CUS30M18 CUS30M36 CUS60M5 CUS60M15 CUS60M48 CUT35522/B HWS30A12/ME RWS150B15 RWS150B28 RWS600B36/RFO HWS600-12/HD ZWS15B3 ZWS30B3 SCS403 SCT47 SCS4015 SCS4028 MTW15-51212/V MTW15-51515/V RWS50B12/CO2 RWS50B24/CO2 RWS50B48/CO2 RWS50B5/CO2 MTW30-51212/V MTW30-51515/V HWS30A24/ME HWS30A48/ME HWS30A12 HWS30A15 HWS30A24 HWS30A3 HWS30A48 HWS30A5 SCT68 RWS100B15 ZWS50BAF48 HWS30A12/HD HWS30A15/HD HWS30A24/HD HWS30A3/HD HWS30A48/HD HWS30A3/ME ZWS50BAF-12/L ZWS50BAF-15/L ZWS50BAF-24/L ZWS50BAF-3/L ZWS50BAF-48/L ZWS50BAF-5/L ZWS50BAF-12/A ZWS50BAF-15/A ZWS50BAF-3/A ZWS50BAF-48/A ZWS50BAF-5/A ZWS50BAF-12/CO2 ZWS50BAF-15/CO2 ZWS50BAF-24/CO2 ZWS50BAF-3/CO2 ZWS50BAF-48/CO2 ZWS50BAF-5/CO2 RWS100B12/CO2 RWS100B48/CO2 RWS100B5/CO2 ZWS75BAF3 ZWS75BAF15 ZWS75BAF48 ZWS75BAF-12/L ZWS75BAF-15/L ZWS75BAF-24/L ZWS75BAF-3/L ZWS75BAF-48/L ZWS75BAF-5/L MTW60-51212 HWS50A48 HWS50A15/ME HWS50A48/ME HWS50A5/ME ZWS75BAF-12/A ZWS75BAF-15/A ZWS75BAF-24/A ZWS75BAF-3/A ZWS75BAF-48/A ZWS75BAF-5/A ZWS75BAF-12/CO2 ZWS75BAF-15/CO2 ZWS75BAF-24/CO2 ZWS75BAF-3/CO2 ZWS75BAF-48/CO2 ZWS75BAF-5/CO2 RWS150B12/CO2 RWS150B24/CO2 RWS150B48/CO2 RWS150B5/CO2 MTW60-51212/V MTW60-51515/V ZWS100BAF-3 ZWS100BAF-15 ZWS100BAF-48 CUS200LD7R5 CUT75522/T CUT755FF/T ZWS100BAF-3/L ZWS100BAF-5/L ZWS100BAF-12/L ZWS100BAF-15/L ZWS100BAF-24/L ZWS100BAF-48/L CUT75522/TB CUT755FF/B CUT755FF/TB CUT75522/B ZWS100BAF-3/R ZWS100BAF-5/R ZWS100BAF-12/R ZWS100BAF-15/R ZWS100BAF-24/R ZWS100BAF-48/R ZWS100BAF-3/A ZWS100BAF-5/A ZWS100BAF-12/A ZWS100BAF-15/A ZWS100BAF-24/A ZWS100BAF-48/A ZWS100BAF-3/CO2 ZWS100BAF-5/CO2 ZWS100BAF-12/CO2 ZWS100BAF-15/CO2 ZWS100BAF-24/CO2 ZWS100BAF-48/CO2 CUT75522/A HWS50A12/RA ZWD100PAF0524 ZWS150BAF-3/L ZWS150BAF-5/L ZWS150BAF-12/L ZWS150BAF-15/L ZWS150BAF-24/L ZWS150BAF-48/L ZWS150BAF-3/R ZWS150BAF-5/R ZWS150BAF-12/R ZWS150BAF-15/R ZWS150BAF-24/R ZWS150BAF-48/R ZWD100PAF0524/JL ZWD100PAF0524/L ZWD100PAF0524/A ZWD100PAF0524/JA ZWS150BAF-3/A ZWS150BAF-5/A ZWS150BAF-12/A ZWS150BAF-15/A ZWS150BAF-24/A ZWS150BAF-48/A ZWD100PAF0524/T ZWS150BAF-3/CO2 ZWS150BAF-5/CO2 ZWS150BAF-12/CO2 ZWS150BAF-15/CO2 ZWS150BAF-24/CO2 ZWS150BAF-48/CO2 HWS100A15/ME HWS100A48/ME ZWD100PAF0524/TL ZWD100PAF0524/TA RWS300B12/R RWS300B15/R RWS300B24/R RWS300B48/R RWS300B5/R ZWD150PAF0524 ZWD150PAF0524/J ZWD150PAF0524/JL ZWD150PAF0524/L ZWD150PAF0524/A ZWD150PAF0524/JA ZWD150PAF0524/T RWS300B12/CO2 RWS300B15/CO2 RWS300B36/CO2 RWS300B48/CO2 RWS300B5/CO2 ZWS150BP36 ZWD150PAF0524/TL CUS250LD3 HWS150A12/ME HWS150A15/ME HWS150A15 HWS150A24 HWS150A3 HWS150A48 HWS150A5 CUS250LD5/A ZWD225PAF0524 ZWD225PAF0524/JL ZWD225PAF0524/L ZWQ805224/L ZWQ805222/L ZWQ805223/L ZWQ805225/L ZWD225PAF0524/A ZWD225PAF0524/JA ZWD225PAF0524/T ZWD225PAF0524/TL ZWQ805222/A ZWQ805223/A ZWQ805225/A ZWD225PAF0524/TA ZWQ1305222/L ZWQ1305223/L ZWQ1305224/L ZWQ1305225/L EVS18-16R7/R EVS36-8R4/R EVS57-5R3/R ZWQ1305222/A ZWQ1305223/A ZWQ1305225/A EVS18-16R7/A EVS36-8R4/A EVS57-5R3/A ZWS240BP24/T ZWS240BP36/T ZWS240BP48/T EVS18-16R7/RA EVS36-8R4/RA EVS57-5R3/RA ZWS300BAF24/T ZWS300BAF36/T ZWS300BAF48/T ZWS300BAF12 ZWS300BAF12/T ZWS300BAF15/T ZWS240BP24/L ZWS240BP36/L ZWS240BP36/TL ZWS240BP48/L ZWS240BP48/TL ZWS240BP24/R ZWS240BP24/TL ZWS300BAF24/TL ZWS300BAF24/R ZWS300BAF24/L ZWS300BAF36/L ZWS300BAF48/TL ZWS300BAF36/TL ZWS300BAF36/R ZWS300BAF48/R ZWS300BAF48/L ZWS300BAF12/L ZWS300BAF12/R ZWS300BAF12/TL ZWS300BAF15
ZWS300BAF15/R-ND ZWS300BAF15/TL-ND ZWX180-ND ZWS300BAF24/TA-ND ZWS300BAF24/CO2-ND ZWS300BAF36/CO2-ND ZWS300BAF36/A-ND ZWS300BAF24/A-ND ZWS300BAF36/TA-ND ZWS300BAF48/CO2-ND ZWS300BAF48/A-ND ZWS300BAF48/TA-ND ZWS300BAF12/A-ND ZWS300BAF12/CO2-ND ZWS300BAF12/TA-ND ZWS300BAF15/A-ND ZWS300BAF15/CO2-ND ZWS300BAF15/TA-ND ZWS240BP24/A-ND ZWS240BP36/A-ND ZWS240BP36/TA-ND ZWS240BP48/A-ND ZWS240BP48/TA-ND ZWS240BP24/CO2-ND ZWS240BP24/TA-ND HWS100-24/HDA-ND ZWX240-ND ZWX180/L1-ND ZWX180/L2-ND ZWX180/A1-ND ZWX180/A2-ND CME240P-24-ND RWS600B12/CO2-ND RWS600B12/FO-ND RWS600B15/CO2-ND RWS600B15/FO-ND RWS600B15/RFO-ND RWS600B24/CO2-ND RWS600B24/FO-ND RWS600B24/RFO-ND RWS600B36/CO2-ND RWS600B36/FO-ND RWS600B48/CO2-ND RWS600B48/FO-ND RWS600B5/CO2-ND RWS600B5/FO-ND RWS600B5/RFO-ND ZWX300-ND ZWX240/L1-ND ZWX240/L2-ND ZWX240/A1-ND ZWX240/A2-ND 285-1401-ND JWS70P48-ND ZWX300/L1-ND ZWX300/L2-ND ZWX300/A1-ND ZWX300/A2-ND 285-2546-ND 285-2552-ND SWS600L-24/CO2-ND HWS30024/RY-ND RWS1000B12/R-ND RWS1000B15/R-ND RWS1000B24/R-ND RWS1000B36/R-ND RWS1000B48/R-ND NND151212-ND RWS1000B12/FO-ND RWS1000B12/RF-ND RWS1000B12/RFO-ND RWS1000B15/FO-ND RWS1000B15/RF-ND RWS1000B15/RFO-ND RWS1000B24/FO-ND RWS1000B24/RF-ND RWS1000B24/RFO-ND RWS1000B36/FO-ND RWS1000B36/RF-ND RWS1000B36/RFO-ND RWS1000B48/FO-ND RWS1000B48/RF-ND RWS1000B48/RFO-ND 285-1324-ND HWS300-48/PV-ND HWS300-12/ME-ND HWS300-15/ME-ND HWS300-48/ME-ND HWS30012/PV-ND HWS30015/PV-ND HWS300P-24-ND HWS300P-36-ND HWS300P-48-ND RWS1000B12/CO2-ND RWS1000B15/CO2-ND RWS1000B24/CO2-ND RWS1000B36/CO2-ND RWS1000B48/CO2-ND HWS30024/RYHD-ND RWS1500B12/R-ND RWS1500B15/R-ND RWS1500B24/R-ND RWS1500B36/R-ND RWS1500B48/R-ND RWS1500B12/FO-ND RWS1500B12/RF-ND RWS1500B12/RFO-ND RWS1500B15/FO-ND RWS1500B15/RF-ND RWS1500B15/RFO-ND RWS1500B24/FO-ND RWS1500B24/RF-ND RWS1500B24/RFO-ND RWS1500B36/FO-ND RWS1500B36/RF-ND RWS1500B36/RFO-ND RWS1500B48/FO-ND RWS1500B48/RF-ND RWS1500B48/RFO-ND JWS240P48-ND JWS240P36-ND 285-1366-ND HWS60024/RY-ND RWS1500B12/CO2-ND RWS1500B15/CO2-ND RWS1500B24/CO2-ND RWS1500B36/CO2-ND RWS1500B48/CO2-ND HWS600-48/ME-ND HWS60012/PV-ND HWS60015/PV-ND HWS60024/PV-ND HWS60048/PV-ND HWS600-12/ME-ND HWS600-15/ME-ND 285-1369-ND HWS60024/RYHD-ND HWS600P-24-ND HWS600P-36-ND HWS600P-48-ND SWS1000L36/CO2-ND 1043-HWS600-12/HD-CHP NNS5015-ND HFE160032-ND JWS6008-ND JWS6009-ND HFE160032/S-ND RFE160032-ND CPFE1000FI-12/PH-ND CPFE1000FI-28/PH-ND CPFE1000FI-48/PH-ND RFE160048/S-ND RFE160024/S-ND RFE160012/S-ND RFE160032/S-ND CPFE1000FI-12/H-ND CPFE1000FI-28/H-ND CPFE1000FI-48/H-ND CPFE1000FI-28/CH-ND CPFE1000FI-48/CH-ND CPFE1000FI12/CH-ND 285-2165-ND 285-2164-ND RFE250012/S-ND RFE250024/S-ND RFE250048/S-ND HWS1000-12-ND HWS1000-15-ND HWS1000-3-ND HWS1000-36-ND HWS1000-48-ND HWS1000-5-ND HWS1000-6-ND HWS1000-60-ND HWS1000-7-ND HWS150024/RL-ND HWS1000-24/ME-ND 285-1282-ND 285-1289-ND 285-1292-ND HWS150024/RY-ND HWS15005-ND HWS15006-ND HWS150060-ND 285-1288-ND 285-1291-ND 285-1294-ND HWS1000-12/HD-ND HWS1000-15/HD-ND HWS1000-24/HD-ND HWS1000-3/HD-ND HWS1000-36/HD-ND HWS1000-48/HD-ND HWS1000-5/HD-ND HWS1000-6/HD-ND HWS1000-60/HD-ND HWS1000-7/HD-ND HWS1800T-5-ND HWS1800T-12-ND HWS1800T-15-ND HWS1800T-24-ND HWS1800T-3-ND HWS1800T-36-ND HWS1800T-48-ND HWS1800T-6-ND HWS1800T-7-ND 285-1283-ND 285-1290-ND 285-1293-ND HWS150024/RYHD-ND LZSA-1500-4-ND HWS1800T-60-ND HWS50A15/RA-ND ZWS150BP24/A-ND ZWS150BP24/L-ND ZWS150BP24/T-ND ZWS150BP24/TA-ND ZWS150BP24/TL-ND ZWS150BP36/A-ND ZWS150BP36/L-ND ZWS150BP36/T-ND ZWS150BP36/TA-ND ZWS150BP36/TL-ND ZWS150BP48/A-ND ZWS150BP48/L-ND ZWS150BP48/T-ND ZWS150BP48/TA-ND ZWS150BP48/TL-ND ZWS240BP24/J-ND ZWS240BP24/JA-ND ZWS240BP24/JL-ND ZWS240BP36/JA-ND ZWS240BP36/JL-ND ZWS240BP48/J-ND ZWS240BP48/JA-ND ZWS240BP48/JL-ND
ZWS300BAF15/R ZWS300BAF15/TL ZWX180 ZWS300BAF24/TA ZWS300BAF24/CO2 ZWS300BAF36/CO2 ZWS300BAF36/A ZWS300BAF24/A ZWS300BAF36/TA ZWS300BAF48/CO2 ZWS300BAF48/A ZWS300BAF48/TA ZWS300BAF12/A ZWS300BAF12/CO2 ZWS300BAF12/TA ZWS300BAF15/A ZWS300BAF15/CO2 ZWS300BAF15/TA ZWS240BP24/A ZWS240BP36/A ZWS240BP36/TA ZWS240BP48/A ZWS240BP48/TA ZWS240BP24/CO2 ZWS240BP24/TA HWS100-24/HDA ZWX240 ZWX180/L1 ZWX180/L2 ZWX180/A1 ZWX180/A2 CME240P-24 RWS600B12/CO2 RWS600B12/FO RWS600B15/CO2 RWS600B15/FO RWS600B15/RFO RWS600B24/CO2 RWS600B24/FO RWS600B24/RFO RWS600B36/CO2 RWS600B36/FO RWS600B48/CO2 RWS600B48/FO RWS600B5/CO2 RWS600B5/FO RWS600B5/RFO ZWX300 ZWX240/L1 ZWX240/L2 ZWX240/A1 ZWX240/A2 JWS70P24/508 JWS70P48 ZWX300/L1 ZWX300/L2 ZWX300/A1 ZWX300/A2 EVS36-16R7/R EVS57-10R6/R SWS600L-24/CO2 HWS30024/RY RWS1000B12/R RWS1000B15/R RWS1000B24/R RWS1000B36/R RWS1000B48/R NND151212 RWS1000B12/FO RWS1000B12/RF RWS1000B12/RFO RWS1000B15/FO RWS1000B15/RF RWS1000B15/RFO RWS1000B24/FO RWS1000B24/RF RWS1000B24/RFO RWS1000B36/FO RWS1000B36/RF RWS1000B36/RFO RWS1000B48/FO RWS1000B48/RF RWS1000B48/RFO HWS300-24/ME HWS300-48/PV HWS300-12/ME HWS300-15/ME HWS300-48/ME HWS30012/PV HWS30015/PV HWS300P-24 HWS300P-36 HWS300P-48 RWS1000B12/CO2 RWS1000B15/CO2 RWS1000B24/CO2 RWS1000B36/CO2 RWS1000B48/CO2 HWS30024/RYHD RWS1500B12/R RWS1500B15/R RWS1500B24/R RWS1500B36/R RWS1500B48/R RWS1500B12/FO RWS1500B12/RF RWS1500B12/RFO RWS1500B15/FO RWS1500B15/RF RWS1500B15/RFO RWS1500B24/FO RWS1500B24/RF RWS1500B24/RFO RWS1500B36/FO RWS1500B36/RF RWS1500B36/RFO RWS1500B48/FO RWS1500B48/RF RWS1500B48/RFO JWS240P48 JWS240P36 HWS600-3 HWS60024/RY RWS1500B12/CO2 RWS1500B15/CO2 RWS1500B24/CO2 RWS1500B36/CO2 RWS1500B48/CO2 HWS600-48/ME HWS60012/PV HWS60015/PV HWS60024/PV HWS60048/PV HWS600-12/ME HWS600-15/ME HWS600-48HD HWS60024/RYHD HWS600P-24 HWS600P-36 HWS600P-48 SWS1000L36/CO2 HWS600-12/HD NNS5015 HFE160032 JWS6008 JWS6009 HFE160032/S RFE160032 CPFE1000FI-12/PH CPFE1000FI-28/PH CPFE1000FI-48/PH RFE160048/S RFE160024/S RFE160012/S RFE160032/S CPFE1000FI-12/H CPFE1000FI-28/H CPFE1000FI-48/H CPFE1000FI-28/CH CPFE1000FI-48/CH CPFE1000FI12/CH HFE250048/S HFE250012/S RFE250012/S RFE250024/S RFE250048/S HWS1000-12 HWS1000-15 HWS1000-3 HWS1000-36 HWS1000-48 HWS1000-5 HWS1000-6 HWS1000-60 HWS1000-7 HWS150024/RL HWS1000-24/ME HWS150012 HWS150036 HWS150048 HWS150024/RY HWS15005 HWS15006 HWS150060 HWS150024/ME HWS150036/ME HWS150048/ME HWS1000-12/HD HWS1000-15/HD HWS1000-24/HD HWS1000-3/HD HWS1000-36/HD HWS1000-48/HD HWS1000-5/HD HWS1000-6/HD HWS1000-60/HD HWS1000-7/HD HWS1800T-5 HWS1800T-12 HWS1800T-15 HWS1800T-24 HWS1800T-3 HWS1800T-36 HWS1800T-48 HWS1800T-6 HWS1800T-7 HWS150012/HD HWS150036/HD HWS150048/HD HWS150024/RYHD LZSA-1500-4 HWS1800T-60 HWS50A15/RA ZWS150BP24/A ZWS150BP24/L ZWS150BP24/T ZWS150BP24/TA ZWS150BP24/TL ZWS150BP36/A ZWS150BP36/L ZWS150BP36/T ZWS150BP36/TA ZWS150BP36/TL ZWS150BP48/A ZWS150BP48/L ZWS150BP48/T ZWS150BP48/TA ZWS150BP48/TL ZWS240BP24/J ZWS240BP24/JA ZWS240BP24/JL ZWS240BP36/JA ZWS240BP36/JL ZWS240BP48/J ZWS240BP48/JA ZWS240BP48/JL
영문 원본: TDK PS Input voltage on label does not match the data sheet?
