To help with troubleshooting a circuit board when there is a bad solder joint or faulty component. Freeze Spray can be used to help identify where the issue is located.
To use the Freeze Spray; power and spray the PCB, then wait for the frost to build up. Check for melted areas, if the frost disappears quickly, this could be a good indicator of any elevated resistance or shorted circuit.
Digi-Key Part Number1873-1003-ND Techspray Part Number 1672-10S Freeze Spray 10 oz
