Hi all,
I would like to use one of the components in this series. I have some questions which are listed below, so please could you answer them.
Question from page 4. I would like to have a constant output voltage, so I don’t want the output voltage adjustment to either increase or decrease. So, what should I do to keep the output voltage constant?.
Question from pages 3 and 4. How to turn on and turn off the converter remotely?. If we make connections as described in the specification of Remote on/off under the General specifications. Then, the converter will turn on or turn off permanently. If I’m wrong please correct me.
If using one of the components from this series, then. Don’t we need to use any additional circuitry at the input and output stages?. Usually, we will use some capacitors and inductors at the input and output stages of the converters.
Thank you.
