I PURCHASED ITEM #'S 0039012040 & 39000039 A COUPLE WEEKS AGO AND MY CUSTOMER IS NOW NEEDING SOMETHING TO TEST THEM. PLEASE HELP ME OUT ASAP MY CUSTOMER IS IN URGENT NEED. THANKS FOR THE HELP.
My customer needs something to test the connections. I found the item below but it has to plug into something for my customer to be able read something off of it. looks like it has pogo connections on the back.
P#44281-0001
So maybe something like the mating header. This would have pins on the backside.
Here are some other mating headers that could work.
Is there a way to hook that up to a meter tester to test the connections.
It really depends what the housing is like when it assembled. Do you have access to the end of the crimped wire to check continuity or are you looking to plug this in an check for power. Either way you should be able to use the end of your test leads on the pins of the header.
-Robert
