Trying to repair a Fan Module and need a threaded insert for NMB 8020SA-12M-AL. Data sheet says .169 in hole and .15 in thickness. Looking for a press in threaded insert recommendation that should work. Thank you!
Hello, Chloechler. Thank you for contacting DigiKey.
You may wish to check out part number 1772-1678T-440-B-ND, here: https://www.digikey.com/short/2jzqz9w7
This looks to be about the closest I can spot in stock to what you’re looking for.
Looking for something like this https://www.digikey.com/en/products/detail/tri-star-industries-inc/440X135H/13535323
Would this work? Seems like it should by the data sheet.
Looks close, though taking tolerances into account on both sides, it doesn’t appear that a person would be guaranteed of a proper fit. Going up a size and reaming the holes in the fan a bit to compensate might be a viable approach.
