------Question for XL25W-TO220-20-14-1 Please Put your question below------
初歩的な質問ですみません。
このシートは電気絶縁性はあるのでしょうか?
初歩的な質問ですみません。
Welcome to the TechForum.
Technical assistance was provided for XL25W-TO220-20-14-1
Thermal Insulation only
The air-contact area of ceramic heat spreader is nearly 5 times of aluminum heat sink, under the same volume. In the same condition of
air flow rate, ceramic heat spreaders can perform better. The more contact areas, the more heat can be exchanged by the cooler air.
Thank you
Ryan
