Trying to identify appropriate power conditioner
I am looking for a power conditioner to stabilize the voltage (+/- 5%) for a large format temperature and humidity chamber. The temp and RH chamber has the following general specifications and electrical requirements.
EDIT: there is no problem providing the required voltage and amps from the building, but the building voltage is +/- 10%, as opposed to the needed 5%.
Welcome to the Technical Forum. I am wondering if an isolation transformer would work like on this link: Isolation Transformers and Autotransformers, Step Up, Step Down | Electronic Components Distributor DigiKey
These can provide the isolation from any transient voltage in between the input and output.
We also sell line conditioners on this link: Line Conditioners | Electronic Components Distributor DigiKey
You can review these options to see if you can make one work.Plus posting the question on the forum , you might get some other responses also.
I think you need to consult with a local industrial electrical contractor about this.
Everywhere I’ve worked or lived in the USA has had at best +/-10% line voltage tolerance, usually worse, and 230VAC@30A means you need >7000 VA power handling.
I think to get this AC line precision you’re gonna spend somewhere between $2k to $10k (US).
If I hit this at work I’d check into returning that chamber and buying one designed for normal USA line voltage tolerances.
