Trying to identify either an replacement pcb or the yellow dc female power connector as its broken
I believe the male end is 5.5mm o.d./ 3mm i.d. with a 1mm pin in the centre
We’re not going to have anything to do with the circuit board, you’d likely need to find a scrapped unit to harvest from.
Closest jack option I’m seeing:
Part Number: PJ-019 from Same Sky (Formerly CUI Devices)
