Trying to identify this connector
Hi everyone, would appreciate some help here.
This terminal and connector is used within the circuit board inside of a Toyota headlamp assembly. One of the wires was pulled and snapped which I’m trying to find the female terminal.
This connector is a 3 pin connector with a pitch of 4mm between pins, with the pins being square. The terminal has an odd shape from the front, where it is not rectangle but shaped like a T. The connector has the word ‘OTP’ on it.
Thanks in advance.
Compelica
Thank you for contacting DigiKey , I am not finding anything with the marking OTP can you take some pictures of the connector these contacts go in ?
Thanks Craig
Have managed to find it - the terminal has the ID 711612-2m, though I do not recognise the manufacturer.
Unfortunately we do not carry this terminal.
