I am looking for a substitute for damaged TVT14511 thermally protected MOV manufactured by THINKING ELECTRONIC INDUSTRIAL Co., LTD. Original Series DataSheet attached.
Damaged TVT photo below.
The MOV is a part of battery charging electronic circuit and it must be thermally protected with similar or better specifications.
I was looking through the catalog on web site, and EATON MOV looks very similar to TVT series. The package has the same yellow color. Series DataSheet from web site attached.
Could you please assist with the substitute opt out?
Thank you ![]()
en-Metal Oxide Varistor-TVT Series.pdf (2.5 MB)
eaton-movtp-metal-oxide-varistor-thermal-protected-data-sheet-elx1079-en.pdf (2.5 MB)
