Understanding Mini-LED Displays and Local Dimming
Mini-LED backlighting significantly enhances LCD performance by increasing luminance, improving contrast, and enabling finer power control. The key technology behind this improvement is local dimming.
What Is Local Dimming?
Local dimming allows each backlight zone to adjust brightness independently. Mini-LED arrays—often thousands of LEDs across hundreds to thousands of zones—offer granular illumination control. This enables deep blacks in low-luminance regions while maintaining peak brightness in highlights, reducing perceptible halo and improving visual fidelity.
Benefits of Mini-LED + Local Dimming
  • High contrast and near-OLED black levels through dynamic zone dimming
  • Greater HDR performance with higher peak brightness and stable ABL behavior
  • Reduced blooming via increased zone density and faster dimming response
  • Power efficiency by driving only active regions instead of full-panel illumination
Key Engineering Considerations
  • Zone count and layout: Higher density → better performance but higher BOM and processing latency
  • Thermal design: Dense LED arrays require optimized heat spreading, TIM selection, and PCB design
  • Driver IC architecture: Multi-channel drivers with PWM/ADC resolution, communication bandwidth, and closed-loop current control directly influence dimming precision
  • Diffuser and optical stack: Critical to balancing uniformity vs. localized contrast
Mini-LED with advanced local dimming offers a cost-effective path to HDR-grade performance, bringing LCD technology closer to OLED in terms of contrast and visual impact—ideal for gaming, automotive, professional monitors, and home entertainment displays.
