Vag 26 pin 4m0972126 and 4m0972726
afternoon everyone, can someone please help identify what part this is? cant find any supplier other than OEM.
as far as i can tell, they’re pretty much the same, just different colors. PN are 4m0972126 for the white and 4m0972726 for the blue.
if it helps, they have the following written on them:
white: on the cover: F880410 B and S280410 B; on the actual connector: F580410 A
blue: on the cover: F980410 B and S380410 B; on the actual connector: F480410 A
thanks!
Hi lgtmelo,
I could not find much on these.
Everywhere I look these seem to be Volkswagen parts but they show as unavailable. We don’t carry the Volkswagen parts so we aren’t going to have these connectors, nor can we obtain them via a special order request.
Sorry for the inconvenience.
still, i appreciate your prompt reply. would you be able to guess what pin (the actual metal connector that is crimped to the wire) these would use?
thanks!
You don’t want to guess with things like this. The contacts any specific housing takes are meant for that specific housing, or series of housings, so even locating some that look like it would fit, would still likely not work if the located contacts are not meant for that housing.
