Hi,
I would like to order this connector. Appreciate if you can direct me to right part number.
Voltage supply: 110 V AC
Number of pins: 3
Female
Connects to Omega Universal Indicator
Thank you.
Hello bhushanp512! I took some time to do a thorough search of the connector category this would belong to, but unfortunately we don’t seem to carry this connector, or any equivalent.
Hi bhushanp512,
Welcome to the TechForum.
I believe that part is a Weidmuller Unimate BLA series part (note the “BLA” marking on your part). Specifically, the orange version is part number 1281860000. Unfortunately, it is obsolete and we no longer have stock. We do still have stock of the grey version of the same part, the 1281800000.
For some reason, our image is wrong for this part on our website. It does in fact look like your part other than the color. Here is a link to the product on the Weidmuller website. Note that their image shows an 8-pin orange version of the part, but if you look at the datasheet they link to on that product page, you’ll find that it is the 3-pin grey version.
Click on “PDF datasheet” highlighted above, then on “Download data sheet” in pop-up, as indicated below:
As a note, we also carry the little white keying plug (the little white piece of plastic above the middle contact of your connector) if you need it, as the following part number: 1323560000. It comes in a little star-shaped piece with four keying plugs to be broken off as needed, as shown below:
Thanks David.
Grey color sound great. I am glad that it is available. Whatever fancy equipment you have, it is of no use without an appropriate connector.
Thanks for directing to the datasheet on the Weidmuller website
I am proceeding with the order now.
Thanks, Chris, for looking into it.
