10mm wide x 6.22mm height power connector female housing with male pins. I need the male housing with the female pins to finish project
Thank you all.
Thank you all.
I could not come up with a mating connector for this one.
Is there a part number or any markings on the connector you already have?
None that I can see. I’ll see if I can safely take apart the display. It’s very similar to the molex power connector on an IDE hard drive only 2 wires instead of 4 wires. I have tried reaching out to the manufacturer but they couldn’t give me a part number to a wiring harness or tell me the connector. It is a LCI (Lippert Components) One Control MyRV wifi gateway and display. Both use the same power connnector.
