Looking to identify internal connector
Technical reference T4525873
I need help to source replacement internal female connectors for an automotive type , modular wiring harness connector. The only marking on the connector are “W-4”. It is OEM Yamaha motorcycle part. Any help in finding this would be greatly appreciated. I have attached pics . Thanks!
Hi,
Welcome to the Digikey tech forum. I’m not able to ID the contact in the photo. Best way to find the contact is to get the part number to the housing it’s used in .
The only numbers on the outside on the connector are: 5-3
michaelbdoherty,
Thank you for contacting the Digi-Key TechForum.
Contacts are specifically designed to fit into certain housings. We do not have a match to this connector, so we will not have a match for the correct contact.
I have the exact same part i need more of, except mine is attached to an ECU on a 2000 Suzuki SV650, they are plugged into a quick disconnect, as the photo, i will also attach a photo of the ECU, the only marking on the conmecter are 1-1 and on the ECU are J54 20F0 BB7708 0J23, as in the pictures
If you could find another connector or more of the crimp things the wire connect to that plug into the connector that would be amazing
Welcome to the DigiKey TechForum. I wasn’t able to find this connector or contacts in our system. You may want to check here to see if you can find what you need.
