I am needing a valid Part Number for an RNC55 series (MIL-PRF-55182) Resistor, 727K ohms.
Hi tim.johnston,
Unfortunately we do not carry a through-hole resistor in our system that has a resistance level of 727kOhm, sorry for the inconvenience.
Hi tim.johnston,
See below for the decoder for RNC55 part numbers. Note that there are multiple variations, depending on not just the resistance value, but also temperature characteristics, tolerance, failure rate, and packaging.
For the value 727k, it would be “7273”. However, 727k is a non-standard value for a resistor. Following the standard E192 series for standard resistor values, the nearest standard values would be 723k and 732k.
