3M
Webinar Date: August 23, 2023
3M EMI Shielding and Grounding Solutions for Dynamic Design Challenges
This post covers Key Takeaways and Frequently Asked Questions from the 3M EMI Shielding and Grounding Solutions for Dynamic Design Challenges webinar regarding EMI/RFI Shielding Solutions and Conductive Tapes. Whether you’re a seasoned professional or a curious newcomer, you’ll find plenty of valuable information watching the webinar. Links to the Webinar, Resources, and Related Content are provided within the post. A copy of the PowerPoint presentation will be provided for customers that register to watch the recorded webinar. All Snippets and Content Compliments of 3M.
Key Takeaways
3M offers worldwide leadership from decades of expertise in materials technology and EMI/RFI challenges including dynamic EMI shielding and grounding
3M offers multiple tape types including conductive adhesives, carriers, and conductive fillers providing various flexibility, conformability, adhesion, temperature and shelf life while offering moisture resistant, low outgassing, no-nickel or non-magnetic conductive options along with various axis (XYZ) electrically conductive fabric, copper foil, and adhesive transfer tapes
3M’s EMI/RFI solutions are known for boosting signal-to-noise ratios (SNR) in consumer electronics, to helping improve antenna signal integrity on 5G towers, and even grounding displays in automotive, industrial, and connected products
Minimize EMI noise and crosstalk, improve signal-to-noise ratios, obtaining high-performing reliable materials while being more cost effective by using quick and easy peel-and-stick solutions
3M offers support and key contacts, along with product support from DigiKey
DigiKey offers low (if any) minimum order quantities, short lead times, and multiple sizes with fast and reliable service
Can any of these tapes be used to hold welding assemblies together, and then welded on?
- No, the tapes aren’t used to hold assemblies together.
Do you have examples of how the tape can be used to create a shielding can? The tape must be grounded around the perimeter of the area but not short against components.
- Yes, you can see a demo video here: EMI Management - Consumer Electronics | 3M US
Great presentation. I would also be interested in seeing another webinar about RF absorber solutions, particularly thin RF absorbers with/without shielding.
- Thank you for the great feedback. We are launching two new absorbers in 2023. One is for high temperatures and the other is for the 5G band.
Can you provide a detail and functional use cases of the AB6000HF series tape?
- We will follow up with you after the webinar. The AB6000HF series is for EMI absorbing vs EMI shielding and grounding.
Can the 9703 product be used in surface mount applications in place of solder?
- No, 9703 doesn’t meet the requirements to replace soldering. It’s for general flex and interconnect applications.
When design for cable (twisted pairs) EMI shielding, what’s the best practice of percentage of unshielded cable in either ends of the cable?
- The best practice is 100% covered for high frequencies.
Will this work on a small cable for RFI?
- Yes. The fabric tape such as 5113sft is a great solution for wrapping that cable.
Does 3m offer any anisotropic conductive elastomeric pads. These are thin, compliant interconnect layers that conduct in Z axis only. Typically used for ITO contact to circuit boards. I need non-adhesive pad, ~0.4mm thick x 50mm x 50mm for IC testing.
- We supply anisotropic conductive adhesives (9703) and Conductive Films (9703) these will be much thinner… that the .4mm pad.
Can you send the URL for the video on RF Shielding Can Replacement, please?
- Yes, you can find it here: EMI Management - Consumer Electronics | 3M US
Webinar Links and Resources
Webinar Registration Link:
DigiKey Webinar Center:
DigiKey TechForum Webinar Posts:
Supplier Center:
DigiKey 3M Product Offerings:
Resources:
- All Content
- 3M Electrically Conductive Tapes & Films Selection Guide
- What Tape is Best? 3M Tape by Usage Guide
- EMI/EMC Solutions Brochure
- 3M™ EMI/RFI Management Solutions
- Electrically Conductive Double-Sided Tape 5113DFT Series
- Electrically Conductive Single-Sided Tape 5113SFT Series
- Electrically Conductive Single-Sided Tape 1050TC Series
- 3M™ Electrically Conductive Tape 5113 Series Flyer pdf
- 3M™ Electrically Conductive Double-Sided Tape 5113DFT Series Datasheet
- 3M™ Electrically Conductive Single-Sided Tape 5113SFT Series Datasheet
- Electrically Conductive Adhesive Transfer Tape 9703 Product Highlight
- RF Shields (Faraday Cages)
Example Webinar Slides
-Much more in-depth slides and a copy of the PowerPoint presentation will be provided for customers that register to watch the recorded webinar.
