What are the differences between soldering terminals and #187 tab terminals for a basic switch?
Question:
Block
Answer:
Soldering terminals and #187 tab terminals have the same outline and can be connected to #187 connectors. However, if the product requires conformity to the safety standards, do not use the soldering terminal as a #187 tab; otherwise the product cannot be guaranteed for the safety standards. The hole shape of the soldering terminal is not approved as a tab terminal according to the safety sta
Block
Explanation:
The soldering terminals of our V type basic switch have a “keyhole” shape, which combines the 2 holes of φ2.4 mm for easy insertion of lead wires and φ1.6 mm for the #187 connector. As a result, both soldering terminals can be connected, and the solder can flow easily with silver plating.
Block
Product category
Switches Basic Switches
Classification
Trouble shootings
Related keywords
Basic Switch
Soldering Terminal
#187 Tab
#187 Connector
V Type Basic Switch
Block
Please visit the link below to see this product category on the Digi-Key website
Switches | DigiKey Electronics
https://components.omron.com/us-en/faq/switches/FAQE20044
