I need to make a breakout board for Fanuc data cables based on 20 pin Honda Tsushin Kogyo connectors. It will be modeled after Fanuc part A20B-1005-0340. Their board has soldered-in pins expressly for attaching scope leads. The pins are cylindrical and necked down near the tip so that the leads won’t slip off. Some versions of the board use flat pins with a hole near the top to hook with a lead. Can you direct me to a suitable pin? Thank you.
Hello ph1ll1p,
Welcome to the DigiKey Techforum.
Click Here for the closest options we have available.
I’m sorry, but we do not have a match to the round pins with the indent near the top.
