This search for 4 pin AMPMODU MTE connectors gives me 6 options (4 receptacles and 2 plugs) - but I can’t see any obvious differences between them. Can someone tell me what’s different between them?
Hello julian - welcome to the Forum community. I did side by side comparison of the parts you mentioned on TE’s website. It’s mostly a matter of whether there is a strain relief included, or packaging. Here is that link scroll right to see all the part numbers
I highlighted differences. They differ by minimum order quantity, plug or receptacle (with male or female pins, respectively), and by contact gold plating thickness.
The male/female part I’d figured out, and some have the same gold contact thickness; but Jenny found the extra info- it’s both about the packaging and plating (bright or matte) for the solder side/non contact side of the pins (not in Digikey’s database.)
