------Question for ROBOT-CHASSIS-3 Please Put your question below------
What is the size of the Robot Chassis 3?
Would 60mm diameter wheels fit on this Chassis?
Thank you.
Thank you.
Hello itsyaboisteve36,
There isn’t much information on this Chassis from the Olimex LTD. I’m trying to contact them to find out about your inquiry and will post a reply here once I have some feedback.
Regards,
Hi again itsyaboisteve36,
I’ve received a reply from Olimex and they inform that “there is no limitation about size of the wheels.”
That is all they said. They gave no actual drawing, and no other information on the size of the chassis. If you’d like me to gather more information from them I could try again, unfortunately I don’t have much else.
Regards.
If it’s of any help Olimex sells this wheel/motor:
WHEEL-MOTOR Olimex LTD | Maker/DIY, Educational | DigiKey
They don’t say but it does look like this wheel would be around 60~65mm in diameter.
