What resistor to use in a Philips remote control
Hi peeps,
As you can see there are gunky parts on this remote control board thanks to a leaky AA battery, while the other parts are working fine, I do need to replace the light blue/stripy resistor which is facing upwards..as you can maybe tell it has snapped off!
There are no markings on them to easily identify a replacement, so I am seeing all kinds of variations with different ohms and watts; can anyone please point me to a suitable replacement?
Many thanks in advance
George
The Brown-Black-Red will be 1000 ohms (1K ohms), and a gold band at the end is 5% tolerance, and a Silver band is 10%. The match for the better 5% tolerance is 2019-CF1/4CT52A102JCT-ND, which is a 1/4W rated.
Thank you again David
