What the part number
WHAT THE PART NUMBER
Hello james.mackinen,
It may be a Diode or TVS. What is the physical size (Length x Width)?
Can you provide more pictures, to see how it is attached to the board, and what type of terminals are on the part?
Is there a part identification number on the board, like Dxx?
Do you know anything about the part, or the voltage & current ratings it needs to handle?
need both assume this is a Zener goes to charger pin to ground
pd701
pjp700 location on board. Dell laptop 7400 wrong charger was used both shorted .368 same part different location
AI said the last one is PMEG6010CEJ.pdf https://share.google/caxYifnnBQ9lqaOXA
This part may be a small tantalum or similar type of capacitor. Some of them look quite similar to this.
Is it relatively tall compared to its length and width? What are its dimensions?
OK, my best guess is probably a KO-CAP polymer electrolytic capacitor from Kemet/Yageo.
It’s likely one of the following (note height difference):
From the datasheet:
