Smd identification
  1. trying to id this part, burnt on pcb, appears to be a diode (0.6 forward biased, 1.566 reverse biased) connected across 12 vdc input to pcb, looks like reverse protection not sure if just a diode or zener or transient voltage suppressor ? thanks
Can you provide a better photo of the part so I can see what the package/case size looks like?
Thanks for emailing me, I ended up finding the same component on the board in the opposite corner, looks like it was just a filter cap on the 12 volt input line, 100uF/16 volt tantalum.
Use a 478-9490-1-ND to replace it. I should go find that post and close it.
Strange no reason that I could find that it blew up and shorted, customer went away happy. :blush:
andy
FYI, responding via email results in any signature information that’s included getting posted to a public forum, where it can be sucked up by spambots. I’ve deleted that info on your behalf, but please bear in mind for future communications.
That’s not terribly uncommon for tantalums of a certain flavor…
