Question:
When is a tactile switch with a ground terminal used?
Answer:
A tactile switch with a ground terminal is used when reducing the risk of damaging the circuit due to static electricity is needed.
Explanation:
If electronic components are mounted on a circuit board or its circuit on which a tactile switch is mounted, static electricity may flow through the tactile switch and damage electronic components (e.g. ICs). We have products with a ground terminal on the cover to prevent it. The circuit must be designed so that static electricity is released from the ground terminal.
[Model with ground terminal]
- Through hole terminal: B3F, B3W (IP67)
- Mounting terminal: B3S (IP67 equivalent), B3SN (IP67 equivalent), B3U
Product category
Switches Tactile Switches
Classification
Usage, Applications
Related keywords
Tactile SwitchGround terminal Static electricity
Please visit the link below to see this product category on the Digi-Key website
Switches | DigiKey Electronics
