One of the pins is broken and I want to buy a new one, it’s part of Hobot 298
Thanks!
Hello itay.public,
I beleive that connector is the 455-2267-ND from JST.
The socket contacts for that are here however only one is in stock and that one takes the 22-28AWG. If you need the one that is 26-30AWG you can still place it on order but it will have a lead time.
Hope that helps. Regards.
Thanks! but I think it’s a different one (I don’t see the “teeth”).
Anyway, can I get it wired here as well?
I’m not sure what “teeth” you’re referring to on the housing side. If you take a look at that housing you can 360 view it. The housing doesn’t have the contacts inside it.
We do have the wires terminated to some of those contacts meant for this housing. Take a look at the options here.
Thanks for your replies!
