Hi, Need help with choosing a LED Strip.
Requirements
- 24V addressable RGB
- Dual Input
- SMD2835 chip
- Cuttable 50-80mm
- Lowest power consumption per pixel
Thanks
Requirements
You can select a 24V addressable LED strip with external driver chips like WS2811 or similar compatible with the SMD2835 LED. Here is a project that you may also like:
Welcome to the technical forum. I do not see the size 2835 listed. I can provide a link of ![]()
I did not have any way to narrow down by the voltage . I checked some of the data sheets and they were listing 5 volts on the options I checked. The only way to check the power is in the data sheet and most do not list by the pixel.
