Why 288T232R161A1 encoder turn ccw or cw only 1 funtion
為何 288T232R161A1 encoder 順時針 或 反時針轉動時 只能顯示1 個方向移動而無法顯示順時針 或 反時針移動
Hello teng.ka688,
Welcome to the DigiKey TechForum!
In reviewing the 288T232R161A1, this is an incremental encoder. This means it uses pulses to count the number of turns in each direction. Have you been able to test it electronically? I ask because the fact it initially works in CW or CCW indicates that there is nothing directionally wrong with it. What application are you using it for? If you have a program reading it, it’s possible it’s meant to only increment and not decrement.
