Hello, I’m looking a winstar display replacement. The screen is labeled as WDO0053-THE#00
Its connected on the mainboard and it has 8 pins soldered
Thanks
Antoine
Add images
Thanks
Antoine
Add images
I too am not able to verify that screen either.
Would you have an image of the screen?
Would you have dimensions for it?
Also any further specifications that we could use to see if we have a match?
Add images
The screen is 60mmx35mm
Hello Antoine,
I do not see any matches in our system, for these part numbers.
Also we do not have a Winstar match to those dimensions.
Thanks for you support!! ![]()
Hi Antoine,
I hope you’re well?
The part number from Winstar is a customised LCD display, which is why you cannot easily find the part online. We are a Winstar distributor and recognise the part numbering system.
Unfortunately as it’s a customised LCD, you will need to contact the manufacturer directly.
I hope that helps!
Ryan Goodger
Midas Displays
