Working with the sps30 and esp32 in micropython
Hello!
I am trying to make the sps30 work with the esp32 but with micropython. I found a library online but it tested using raspberri pi: sps30/sps30.py at master · feyzikesim/sps30 · GitHub so I tried converting it to a usable code for esp32.
I am having problems writing on the i2c bus For example, on the original code:
SPS_ADDR = 0x69
R_ARTICLE_CD = [0xD0, 0x25]
 def read_article_code(self):
        result = []
        article_code = []
        write = i2c_msg.write(self.SPS_ADDR, self.R_ARTICLE_CD)
        self.bus.i2c_rdwr(write)
        read = i2c_msg.read(self.SPS_ADDR, 48)
        self.bus.i2c_rdwr(read)
        for i in range(read.len):
            result.append(bytes_to_int(read.buf[i]))
        if checkCRC(result):
            for i in range (2, len(result), 3):
                article_code.append(chr(result[i-2]))
                article_code.append(chr(result[i-1]))
            return str("".join(article_code))
        else:
            return self.ARTICLE_CODE_ERROR
The code I was able to do was:
SPS_ADDR = b'\x69'
R_ARTICLE_CD = bytearray([0xD0, 0x25])
        result = []
        article_code = []
        write = bytearray(self.R_ARTICLE_CD)
        self.i2c.writeto(self.SPS_ADDR, write)
        time.sleep(0.1)
        read = bytearray(48)
        self.i2c.readfrom_into(self.SPS_ADDR, read)
        else:
The terminal outputs TypeError: can’t convert bytes to int on the self.i2c.writeto(self.SPS_ADDR, write) line. I’m guessing this would happen on the read part also.
I am hing that maybe someone here could help me? Thanks!
I think the conversions you are doing are unnecessary. The ESP32 I2C example uses software I2C via a bit-banging method through the machine.SoftI2C class.
Here is the MicroPython Quick Reference for the ESP32 which includes an I2C example
