Hello, do you know what kind glue or resin must be this yellow transarent on the attached picture? There is a special category for electonics?
For instance I know that on electronics you don’t have to put an ordinary silicone glue because will corode the pcb and the leads of the components and for that we use RTV type like this (RTV162-85ML).
That looks like ordinary Devcon 5 minute amber two-part epoxy which is safe for most electronics. It’s available at many hardware stores in the USA for less than $10.00US for a 25ml twin tube dispenser pack.
There are many equivalent epoxies from other manufacturers. I suspect DigiKey has something equivalent but I’m not sure.
Hello! I think Paul has the right idea here. We do have several 2 part epoxy items that might suit you, they are at least similar and made for use with electronic components- part number 473-1226-ND looked like a good option in my search.
Clear/translucent epoxy becomes amber over years due to UV exposure, it might have started out clear.
