Happy New Year folks.
So I’m replacing a relay on a small water heater. The one I ordered has an extra port (NO,NC) OLD relay has 4 pins. New relay has 5. Do I need to create a ground or do I ignore the 5th pin?
please take a look at part 2487-AZ2280-1A-12DEF-ND the added E in the suffix is epoxy sealed version IP67. Thank you for checking out Digi-key Form.
The additional terminal should be ignored or permanently capped off with a suitable insulating material to prevent incorrect connection of the sort indicated in the photos above.
