103020132 Technical Specs & Pinout
------Question for 103020132 Please Put your question below------
Is there a datasheet to explain the technical characteristics and connections for this relay board?
Hi jad,
Welcome to the Tech Forum.
There is no datasheet per se for the Seeed 103020132. There is a datasheet for the relay they use, here:
The description, technical specs, and connection information can be found here:
Here is the pin mapping for the board:
