3.5mm Jack that fits in standard breadboard
Hi I’m looking for either a stereo or a mono 3.5mm/1/8 inch audio jack that can fit in a standard breadboard. I’m not sure how to navigate the site to be able to find what I’m looking for. The location of the jacks pins doesn’t matter too much as I am in the design phase of my project.
Hello @nineseventytwo !
Welcome to the DigiKey Tech Forum!
Please hold while we take a look to see what we can find.
Thank you,
Victoria.
Take a look at our catalog options HERE.
I hope this helps to narrow down a possible part for your project needs.
Please let us know if you have any additional questions.
Thank you,
Victoria
Thanks for the quick reply. I’ve been looking in your catalog. I guess my question is how would I know if the pins spacing would fit into a standard breadboard from what I can see in the listing in your catalog?
The datasheets for the respective products provide information on contact spacing/board layout.
As a general rule however, such products are not designed for direct use with breadboards and will not fit without use of an adapter mechanism of some sort, of which a few soldered-on wire leads are the simplest and easiest to come by.
Thanks for the information.
