Hello I am looking for a version of the this motor with a 0-5V command signal.
Thank you
Thank you
Greetings,
The part number mentioned incorporates a BLDC motor without integrated drive electronics; these must be supplied externally, with a device such as the 381-992.0640.004-ND being the example of such mentioned in the product datasheet.
That particular controller accepts a 0~12v analog control input;; a simple op amp circuit could allow full use with a 0~5v signal. Alternatively, an appropriate 3rd party BLDC controller could be used, or a purpose-built drive circuit created.
