968-038 DGS-SO2 DIGITAL GAS SENSOR MODUL COMMs
968-038
SPEC Sensors, LLC
to an industrial plc which communicates ASCII through a configurable rj12 port
What do I need
C232HD-EDHSP-0 or something cheaper and A-USB-4
Hi Walt,
Thank you for your first post on our TechForum. Do you know how many wire UART the PLC has? If the number of wire is not visible, what is the model number of the PLC that you are using?
