We are planning to use the A10XSR10 pre-built cable assembly in a tight space in our design. The cable will take an immediate 90 degree turn so I would like to know the following to see if this is okay:
- It seems to use 36 AWG wire based on the part number. Can someone please confirm this and also tell me what the stranding scheme is? I assume 7/40, but finer would be better.
- What is the jacket material and thickness?
- What is the minimum bend radius coming out of the back of the JST connector?
Thank you,
Jamie
