About this product : RP-HH-01-CM4
------Question for RP-HH-01-CM4 Please Put your question below------
Can you customized this one for this board : https://assets.koheron.com/datasheets/koheron_alpha250-signal-acquisition-generation.pdf
thank you.
Greetings,
Custom modifications to the product (if even available) would need to be arranged with the manufacturer, and would be subject to minimum order quantities, set up fees, and lead times which are all likely to be significant.
A more likely solution would be to fabricate necessary items needed to adapt the item to your purposes, or to construct your own using a product from the heat pipe family and some chunks of aluminum. I highly recommend SendCutSend.com as a source for such things if you do not have access to necessary tooling.
